Abaqus to Radioss Conversion Mapping
Elements
| Abaqus (Explicit) | Radioss |
| B31 | BEAM3N |
| C3D10M | /BRICK |
| C3D4 | /BRICK |
| C3D6 | /BRICK |
| C3D8R | /BRICK |
| C3D10 | TETRA10 |
| C3D10I | TETRA10 |
| S3R | /SH3N |
| S4R | /SHELL |
| SC8R | /BRICK |
| SC6R | /PENTA6 |
| R3D3 | /SH3N + /RBODY |
| R3D4 | /SHELL + /RBODY |
| MASS | /ADMAS |
| M3D4R/M3D3 | /PROP/SHELL |
Properties
| *BEAM GENERAL SECTION | P3_BEAM |
| BEAM SECTION | /PROP/INT_BEAM |
| *CONNECTOR SECTION, AXIAL | /PROP/SPR_BEAM |
| *CONNECTOR SECTION, HINGE | /PROP/SPR_BEAM |
| *SOLID_SECTION and *CONTROL_SECTION | /PROP/SOLID |
| *SHELL_SECTION and *CONTROL_SECTION | /PROP/SHELL or PROP/TSHELL |
| *RIGIDBODY | PROP/SHELL or /PROP/SOLID |
| *MASS | /ADMAS |
| *SHELL SECTION COMPOSITE | /PROP/TSH_COMP(P22_TSH_COMP) |
| SPRING(Nonlinear) | P4_SPRING |
Materials
| ELASTIC, ISOTROPIC | /MAT/ELASTIC |
| PLASTIC, ISOTROPIC | /MAT/PLAS_TAB |
| Hyperelastic, Mooney, Rivlin | MAT/OGDEN |
| Hyperelastic, Ogden | MAT/OGDEN |
| PLASTIC,JOHNSON COOK | M2PLAS_JOHN_ZERIL |
| HYPERELASTIC,MARLOW | /MAT/LAW70 |
| HYPERFOAM, VISCOELASTIC | /MAT/LAW62 |
| *HYPERELASTIC Neo Hookean | /MAT/LAW41 |
| *HYPERELASTIC | /MAT/LAW93 |
| *SUPERELASTIC | /LAW71 |
| *LOW DENSITY FOAM | //MAT/LAW70 |
| *EOS, TYPE=USUP | /EOS/POLYNOMIAL |
Functions
| *AMPLITUDE | /FUNCT, /MOVE_FUNCT |
Groups
| *NSET | /GRNOD |
| *ELSET | /GSHEL, /GRSH3N, /GRBRIC |
| *SURFACE | /GRNOD, /SURF |
Loads
| *BOUNDARY | /IMPDISP, /IMPVEL, /IMPACC, /BCS |
| *INITIAL CONDITION | /INIVEL |
| *CLOAD | /CLOAD |
| *DLOAD | /PLOAD |
| *DSLOAD | /PLOAD |
| *INTIAL VELOCITY TYPE=ROTATION | /INVEL/AXIS |
Contacts
| *TIED, *CONTACT_CLEARANCE, *SURFACE_INTERACTION | /INTER/TYPE2 |
| *CONTACT_CLEARANCE, *SURFACE_INTERACTION | /INTER/TYPE7 |
| CONTACT INCLUSIONS,ALL ELEMENT | TYPE24 |
| *CONTACT PAIR | /INTER/TYPE24 |
| GENERAL CONTACT | TYPE24 or TYPE25 |
Constraints
| *COUPLING(DISTRIBUTED) TYPE=NODE | RBE3 |
| *COUPLING (KINEMATIC) | RBE2 |
| *COUPLING KINEMATIC, *COUPLING DYNAMIC | /RBE2, /RBE3 |
| *MPC BEAM | |
| /RBODY |
Output Blocks
| *STEP, STEP NAME | /TITLE and /RUN |
| *DYNAMIC, T_period | /TSTOP |
| *VARIABLE MASS SCALING | /DT/NODA/CST |
| *OUTPUT FIELD | /ANIM/DT, /ANIM/VECT/(ACC, VEL, DISP, FINT, PCONT), /ANIM/BRICK/TENS/(STRESS,STRAIN) /ANIM/SHELL/TENS/(STRESS,STRAIN), /ANIM/ELEM/(VONMISES, PRESSURE,EPSP, ENER, DENS) |
| *OUTPUT HISTORY | /TFILE, /TH/NODE, /TH/SHEL, /TH/SH3N, /TH/BEAM, /TH/BRIC |
