Radioss to PAM-CRASH 2G Conversion Mapping
Elements
| Radioss | PAM-CRASH 2G |
| TRUSS | BAR |
| BEAM | BEAM |
| SPRING | SPRING |
| SPRING+PROP/SPR_BEAM (TYPE 13) | SPRBM |
| SH3N | SHELL |
| SHELL | SHELL |
| BRICK | SOLID |
| TETRA44 | TETRA44 |
| ADMAS | MASS |
| SPRING+INTER/TYPE2 | PLINK |
| SPRING+PROP/KJOINT(TYPE33) | KJOIN |
| RBODY | RBODY |
Boundary Conditions
| INIVEL | INVEL |
| BCS | BOUNC |
| CLOAD | CONLO |
Systems
| FRAME/FIX | FRAME |
| SKEW/MOV | FRAME |
| SKEW/FIX | FRAME |
Materials
| M1_ELASTIC | MAT_1D TYPE 201, MAT_2D TYPE 101 |
| /PROP/SPRING | MAT_1D TYPE 220 |
| /PROP/SPR_BEAM | MAT_1D TYPE 223 |
| M0_VOID | MAT_2D TYPE 100 |
| M36_PLAS_TAB | MAT_2D TYPE 102/103 |
| M44_COWPER | MAT_2D TYPE 102/103 |
| M2_PLAS_JOHNS | MAT_2D TYPE 102/103 |
Properties
| PROP/BEAM | PART, TYPE= BEAM |
| PROP/KJOINT | PART, TYPE = KJOIN |
| PROP/SHELL | PART, TYPE = SHELL |
| PROP/SOLID | PART, TYPE = SOLID |
| PROP/SPRING | PART, TYPE = SPRING |
| PROP/SPR_BEAM | PART, TYPE = SPRING |
| PROP/SPR_GENE | PART, TYPE = SPRING |
| PROP/TRUSS | PART, TYPE = BAR |
Curves
| FUNCT | FUNCT |
Control Cards
| TITLE | TITLE |
| OCTRL/ | |
| /ANIM/DT | DSYOUPUT |
| /TFILE | THPOUTPUT |
Components
| PART | PART |
Contacts
| CNTAC36 | INTER/TYPE7 |
Rigid Walls
| RWALL | RWALL |
Time History
| TH/SPRING | THELE |
| TH/NODE | THNODE |
| TH/FRAME | THLOC |
Sections
| SECT | SECFO |
Groups
| GRNOD/NODE | GROUP |
| GRNOD/GENE | GROUP |
| GRNOD/SUBSET | GROUP |
| GRNOD/PART | GROUP |
| GRNOD/MAT | GROUP |
| GRNOD/PROP | GROUP |
| GRNOD/GRNOD | GROUP |
| GRNOD/SURF | GROUP |
| GRNOD/GRSHEL | GROUP |
| GRNOD/GRBRIC | GROUP |
| GRNOD/GRSPRI | GROUP |
| GRNOD/GRSH3N | GROUP |
| GRNOD/GRTRUS | GROUP |
| GRNOD/GRBEAM | GROUP |
| GENOD/NODENS | GROUP |
| GRNOD/FORMULA | GROUP |
Airbags
| MONVOL | BAGIN |
