Add a Response Variable
                From the Responses section of the Optimization Wizard, click the
                        Add button.
 Figure 1.The Add Response Variable dialog is displayed.
- Click the System collector to choose the parent system for the RV.
- Specify a meaningful label and variable name.
                Click OK.
                Tip: Responses can also be added outside the wizard by right-clicking on Model (or any System) in the Project Browser and choosing Add > General MDL Entity > ResponseVariable.
