ACUNFN
This function reads the units from the UNITS block and then returns the conversion factors from property file units to model and SI units.C Calling Sequence
int c_rto_acunfn(char *units, double *cv2mdl, double *cv2si);
Arguments
| Argument | Type | Description | |
| Units
 | Character Array | Input | This Units (block) is a array of five strings which is read from the TeimOrbit file. |
| cv2mdl | Double Precision | Output | This converts the units from TeimOrbit file to model units. |
| cv2si | Double Precision | Output | This converts the units from TeimOrbit file to SI units. SI units are Newtons, Kilograms, Meters, Seconds, Radians. |
FORTRAN Calling Sequence:
DLLFUNC void STDCALL ACUNFN(char *ptrunits, int dummylen, double *cv2mdl, double
          *cv2si)
Arguments
| ptrUnits
