Read Spline in a Table
This function reads spline in a table of a block in a file. The Spline is a list of X and Y values in a block.C Calling Sequence
int c_rto_read_table_spline(const char *block, int maxPairs, int *nPairs, double
          *values);
Arguments
| Argument | Type | Description | |
| block | Character Array | Input | This contains the block name in a TeimOrbit file. |
| maxPairs | Integer | ||
| nPairs | Integer | ||
| values | Double Precision | Output |
FORTRAN Calling Sequence:
DLLFUNC void STDCALL RTO_READ_TABLE_SPLINE_F2C(char *blockName, int len1, int
          *blockNameLen, int *maxPairs, int *nPairs, double *values, int *Success)
Arguments
| blockName | Character Array | Input | This contains the block name in a TeimOrbit file. |
| blockNameLen | Integer | Input | This contains the number of characters in the block name. |
| values | Double Precision | Output | |
| success | Integer | Output | If the value is read then success return 1 or else 0. |
