Read String
This function reads a string value assigned to an attribute from the specified block.C Calling Sequence
int c_rto_read_string(const char *block, const char *attrib, int *alen, char
          *strvalue);
Arguments
| Argument | Type | Description | |
| block | Character Array | Input | This contains the block name in a TeimOrbit file. |
| attrib | Character Array | Input | This contains the name of the attribute inside a block. |
| alen | Integer | Input | This contains the number of characters in the attribute name. |
| strval | Integer | Output | This returns the string value of the attribute. |
FORTRAN Calling Sequence:
DLLFUNC void STDCALL RTO_READ_STRING_F2C(char *blockName, int len1, int
          *blockNameLen, char *attributeName, int len2, int *alen, char *strvalue, int len3, int
          *valueLen, int *success)
Arguments
| blockName | Character Array | Input | This contains the block name in a TeimOrbit file. |
| blockNameLen | Integer | Input | This contains the number of characters in the block name. |
| attributeName | Character Array | Input | This contains the name of the attribute inside a block. |
| strval | Integer | Output | This returns the value of the attribute. |
| success | Integer | Output | If the value is read then success return 1 or else 0. |
