List 1D Elements from Orientation Nodes
Use the Elements from Orientation nodes tool to extract and create a list in the Matrix Browser of 1D elements that use node as the orientation vector.
View new features for HyperWorks 2022.2.
Create an assembly structure from a .csv file definition.
Checks for the validation of a global FE model.
Checks for model reduction workflow (static/dynamic condensation).
Check CFAST (type ELEM) validity.
