hexa (tapered T)
Hexa Realization Options
| Option | Action |
| width | Define the width of the continuous hexa weld in the direction
                                    perpendicular to the seam direction. Note: Only available for
                                        hexa (adhesive) and hexa (RBE2-RBE3). |
| strips | Define the number of hexa elements required along the width. |
| coats | Defines the number of hexa elements required along the thickness. |
| thickness | Select a method for defining the thickness of a hexa
                    weld.
 Note:
  Figure 3. |
| thickness dependent / angle, D and H / H1, H2 and D | Hexa (tapered T) enables you to create tapered seam hexas for
                                        T-connections. Select a method to define how hexas are
                                        positioned and located, and assign appropriate values to any
                                        corresponding inputs.
| discontinuity | By default, the length and pattern of a hexa weld is defined
                                    by test points along the seam connector. To ignore the
                                    predefined test points, and define a specific element length,
                                    weld length, and break length to realize the connector with,
                                    select the discontinuity checkbox. With this option, a hexa
                                    adhesive seam with alternating weld pieces and gaps is created. When discontinuity is enabled, you must define the
                                        following inputs:
                                        hexa (adhesive) realizations. |
| hexa position to edge | Select a location to create the hexa from the edge.
 Note: Only
                                        available for hexa (adhesive) and hexa
                                    (RBE2-RBE3). |
| edge details | In many cases, the connector position is not very
                precise. To create the requested result, an automatic edge snapping can be enabled.
                In the first step the connector snaps to, for example, the closest free edge, and
                then from there the projection and FE creation starts. Select how many element rows
                away from the free edge to snap the connector to for L and T connections.
