HyperWorks
HyperWorks
2022.2
  1. Home
  2. Connectors
  3. Realizations
    View details for different types of realizations.
  4. Line Connector Realization Types
    A list of realization types that can be specified for line connectors.
  • What's New
  • Get Started
  • Video Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • Panels
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
Index
HyperWorks
2022.2
HyperWorks
  • What's New
    View new features for HyperWorks 2022.2.
  • Get Started
  • Video Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
    • Connector Browser
      Use the Connector Browser to view and modify connectors in the current model.
    • Define Connector Controls
      Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
    • Create and Realize Connectors
      Use the tools in the Create tool set to create connectors, assign controls, and realize.
    • FE Absorb Connectors
      Use the FE Absorb tools to create connectors from existing mesh that meet specific types of realizations.
    • Realizations
      • Point Connector Realization Types
        A list of realization types that can be specified for point connectors.
      • Fastener Connector Realization Types
        A list of realization types that can be specified for fastener connectors.
      • Line Connector Realization Types
        • hexa (adhesive)
        • hexa (seam tie)
        • hexa (tapered T)
        • hexa imprint (adhesive-contact)
        • llink
        • mat196 (single row)
        • penta (mig + B)
        • penta (mig + L)
        • penta (mig + T)
        • penta (mig)
        • penta imprint (adhesive-contact) T
        • seam (vectors)
        • seam-quad (angled)
        • seam-quad (angled+capped+L)
        • seam-quad (angled+capped+T)
        • seam-quad (vertical+angled)
        • seam-quad LTB
        • seam-rigid LTB
        • stitch
        • stitch HL
        • type2 (spring multiple row)
        • type2 (spring single row)
      • Area Connector Realization Types
        A list of realization types that can be specified for area connectors.
    • Element Organization
      Organize elements into connector groups.
    • FE Configuration File
      The FE configuration file (feconfig.cfg) is used to define custom welds such as ACM (Area Contact Method) and other special types.
    • Attachments and Connectors
      Attachments are an entity to facilitate the ease of joining subsystems.
    • CAD Abstraction
      Abstract information incoming from the CAD hierarchy to robustly create connectors.
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
View All Altair Simulation Help
HyperWorks
HyperWorks
2022.2
  1. Home
  2. Connectors
  3. Realizations
  • What's New
  • Get Started
  • Video Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Geometry
  • FE Geometry
  • Meshing
  • Elements
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Design Explorer
  • Validate
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag Solutions
  • Aerospace
  • Aeroelasticity
  • Certification
  • Panels
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
  • hexa (adhesive)
  • hexa (seam tie)
  • hexa (tapered T)
  • llink
  • penta (mig + B)
  • penta (mig + L)
  • penta (mig + T)
  • penta (mig)
  • seam (vectors)
  • seam-quad LTB
  • seam-rigid LTB
  • stitch
  • stitch HL
