Combine Solids
Use the Boolean: Combine tool to connect two or more solids together, retaining all of the material in both.
From the Geometry ribbon, click the Boolean > Combine tool.
Figure 1. - Optional:
On the guide bar, click
to edit the tolerance value.
Select solids in the following ways:
- Click Find on the guide bar to detect solids within the given tolerance.
- Manually select individual solids by left-clicking.
- Click and drag to draw a window. Only intersecting solids in the enclosed region are selected.
Review each intersecting solid by clicking
and
on the guide bar.
Combine solids in the following ways:
- In the modeling window, hover over individual intersecting solid pairs and left-click to combine.
- On the guide bar, click Combine All to combine all of the intersecting solids.
