Density Variation Study
Material stiffness and density is directly affected by the manufacturing process, especially in injection molding for plastic parts.
The Density Study Setup panel is as shown below.
The Density Study Setup panel allows you to perform following operations -
  1. Select Parameter - a default selection list that shows the selected parameter. In this case, Density is the value.
  2. Global Variation % - value entry field to provide the parameter variation range
  3. Select All, Unselect All, Reverse Selection - parameter list selection options
  4. Parameter list table - table listing the material density in the model
  5. Add - to add a parameter variation study to the study table
  6. Update - to update an existing study parameter
  7. Parameter Variation Study table - a table listing the study variations created
