Stochastics Study Setup
SnRD allows you to work with a unique workflow to setup complex Stochastics and Design of Experiment (DoE) problems formulations where industry best practices are incorporated. Altair’s SnRD Pre-Processing Module guides you step by step in the creation of runnable input decks and inputs for HyperStudy and SnRD Post-Processing Module.
The following sections will take you through the steps of creating various variation studies for a model.
