Finds the curve that a curve note is attached to.
Finds the point on the curve that the note is attached to.
Checks if the macro can be edited.
Finds where the note's attachment point.
Finds the note’s X coordinate.
Finds the note’s Y coordinate.
Gets the X coordinate of the point to which a coordinate note is attached.
Gets the Y coordinate of the point to which a coordinate note is attached.
Determines if the macro is a complex macro.
Checks if the attachment point of the complex macro note is in the real or phase plot.
Checks if the position of the complex macro note is in the real or phase plot.
Checks if the complex macro is in the real/imaginary plot.
Sets whether the macro is a complex macro or not.
Sets the attachment point of the complex macro note.
Sets the position of the complex macro note.
Sets the curve that the curve note is attached to.
Sets the point on the curve that the curve note is attached to.
Sets whether the macro can be edited or not.
Sets the note attachment type.
Sets the position of the note.
Sets the X coordinate of the point to which a coordinate note is attached.
Sets the Y coordinate of the point to which a coordinate note is attached.
