pltIMacro SetCurveAttachmentExpression
Sets the curve that the curve note is attached to.
pltIMacro_handle SetCurveAttachmentExpression expr
HyperWorks Tcl Modify
This command sets the curve that the curve note is attached to. This function only works if there is a macro with a note that is attached to one of the curves.
expr
The expression (math reference) of the curve the you want to attach the note to. An expression usually states the exact location of the curve. For example, for a curve on the first page, in the first window, the first curve would have the math reference p1w1c1.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm GetMacroHandle mc 1
mc SetCurveAttachmentExpression p1w1c1
mc Apply original false
Keywords
HyperWorks
Tcl
Macro
Note
Modify
