HMIN_message_send()
Allows you to send a message to the message file while a database is being read in.
void HMIN_message_send(int type, char * message, char * resolution);
HyperMesh hminlib Function
type
The type of message you want to send. Set the type to:
0 - To send information.
1 - To send a warning.
2 - To send an error message.
message
A character string that contains the message you want sent out to the file.
resolution
A character string that gives the your resolution to a problem. If a resolution should not be written set to NULL.
None.
