HMIN_sethmxpath()
Sets the directory where the HMX file is created.
void HMIN_sethmxpath(char *path);
HyperMesh hminlib Function
Sets the directory where the HMX file is created. If the specified location does not have write permission, the file is created in the current working directory.
This is utilized in model readers that use HMX files.
path
The directory where the file should be created. Must use forward slashes for the directory separator.
To set the HMX path to the same directory as the input model (passed as an argument to the model reader):
char pathToFile[256];
pathToFile[0] = 0;
for (int i = strlen(argv[1]) - 1; i > 0; i--)
    if (argv[1][i] == '/' || argv[1][i] == '\\')
        strncpy(pathToFile, argv[1], i + 1);
        pathToFile[i + 1] = 0;
        break;
HMIN_sethmxpath (pathToFile);
None.
Version History
12.0
