result iso display
Upfront Data LoaderChanges the value display.
result iso display <name1>=<value1>
Argument
<name1>=<value1>
The name=value data name and/or attribute pairs that define the relevant data. For attributes, this can be either the attribute name or ID.
currentvalue=<value>
The current iso value.
incrementby=<increment>
Enter a value to move the iso value by this amount.
displayvalues=<above/below>
above - Updates the graphics display so that all elements with result values above the current iso surface level (currentvalue) are displayed (unmasked) based on their display attributes.
below - Updates the graphics display so that all elements with result values below the current iso surface level (currentvalue) are displayed (unmasked) based on their display attributes.
usecolor=<true/false>
Select true to apply a color to the vector.
color=<color>
Select a color from the list or the color palette or enter RGB values to define the color.
Examples
result iso display usecolor=true
result iso display color Cyan
result iso display currentvalue=5
