result iso plot
Upfront Data LoaderPlots the iso data type results.
result iso plot <name>
Argument
- <name>
- The name of the iso results to plot.
result iso plot "Stress, Analysis System"
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Upfront Data LoaderLoad and unload animations.
Upfront Data LoaderCancels all currently loading results.
Upfront Data LoaderCreate and manage iso plots.
Upfront Data LoaderClears the iso plot and returns the model to its original state.
Upfront Data LoaderChanges the value display.
Upfront Data LoaderClears the iso plot from the graphics window.
Upfront Data LoaderControl the iso value displayed on the screen incrementally.
Upfront Data LoaderLoad the iso data type.
Upfront Data LoaderDisplays the current iso plot in the modeling window.
Upfront Data LoaderCreate and manage contour plots.
Set the current simulation.
Makes a subcase current.
Upfront Data LoaderCreate and manage tensor plots.
Upfront Data LoaderCreate and manage vector plots.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Result loading.
