result tensor create
Upfront Data LoaderCreates a tensor data type.
result tensor create <name> <name1>=<value1>, ?<name2>=<value2>?, ... ?<nameN>=<valueN>?
Arguments
<name>
The name of the tensor.
<name1>=<value1>
The name=value data name and/or attribute pairs that define the relevant data for the plot. For attributes, this can be either the attribute name or ID.
averageatnode=<true/false>
Averages elemental tensors to nodes.
cornerdata=<true/false>
If corner data is available, enter true to use the Use corner data option, which displays color bands by interpolating available corner results within each element.
format=<principal/component>
Select the tensor format.
layer=<layer>
The layer definition.
layerfilter=<layerfilter id / layerfilter label?>
Enter the filter ID and value to reduce the layer list.
marked = <true/false>
Enable/disabled marked elements.
principal/component
Load or display any principal or component of a tensor. They include:
  • p1major= <true/false>
  • p2mid= <true/false>
  • p3minor= <true/false>
  • xx=<true/false>
  • yy=<true/false>
  • zz=<true/false>
  • xy=<true/false>
  • yz=<true/false>
  • zx=<true/false>
projectionrule=<none/xy/xz/yx/yz/zx/zy>
For shell (or planar) elements, results in any 3D coordinate system can be projected onto the element plane. Enter none to not use the projection rule.
showmidnoderesults=<true/false>
Calculate and show the tensors at the mid-side nodes if it is not available in the results file.
sset = <sset name>
Enter a selection set name.
system=<analysis/global/elemental/system name>
Enter the coordinate system type that will be used to calculate the results.
type =<typel>
The result type.
Examples
Create tensor datatype definitions:
result tensor create "Stress, Mid, Analysis System" layer=\"Mid\" type=\"Stress\"
