result tensor show
Displays the current tensor plot in the modeling window.
result tensor show
Argument
- show
- Displays the tensor plot in the modeling window.
result tensor showView new features for HyperWorks Desktop 2022.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Upfront Data LoaderLoad and unload animations.
Upfront Data LoaderCancels all currently loading results.
Upfront Data LoaderCreate and manage iso plots.
Upfront Data LoaderCreate and manage contour plots.
Set the current simulation.
Makes a subcase current.
Upfront Data LoaderCreate and manage tensor plots.
Upfront Data LoaderClears the tensor plot and returns the model to its original state.
Changes the tensor color by direction.
Upfront Data LoaderCreates a tensor data type.
Upfront Data LoaderDeletes tensors from the model.
Changes the value display.
Upfront Data LoaderEdits the tensor data type.
Clears the tensor plot from the graphics window.
Edits the tensor plot legend properties.
Defines the legend's maximum value.
Enables the legend's maximum value.
Defines the legend's minimum value.
Enables the legend's minimum value.
Upfront Data LoaderLoads the tensor data type.
The multiplier for scaling the result values.
Upfront Data LoaderPlots the tensor data type results.
Upfront Data LoaderRenames the tensor definition.
Upfront Data LoaderUnloads a tensor data type.
Upfront Data LoaderUpdates the tensor plot.
Upfront Data LoaderCreate and manage vector plots.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Result loading.
result tensor show
result tensor show© 2022 Altair Engineering, Inc. All Rights Reserved.
