::mdlFileName
This command creates an mdlFileName widget that is tied to a FileName data member of an existing entity in the model.
::model::mdlFileName path entityHandle dm args
MotionView Tcl GUI
path
The full path to the newly created widget.
entityHandle
A handle pointing to the entity that contains the data member.
dm
The name of the data member that will hold the value.
args
A list of '-' separated flags to configure the mdlFileName widget's behavior.
To create an mdlFileName widget:
::model::GetClientHandle clnt
clnt GetModelHandle mdl
clnt ReleaseHandle
mdl InterpretEntity entArray SolverArray sa_0 "\"Array 0\"" "IC"
mdl ReleaseHandle
set dlg [toplevel .dlg]
set frm [frame $dlg.frm -padx 10 -pady 10]
grid $frm -row 1 -column 0 -sticky nesw
set fn [::model::mdlFileName .dlg.frm.fn entArray "ic_file.value" -editbar ""]
grid $fn -row 0 -column 0
entArray ReleaseHandle
Returns the path to an mdlFileName widget if successful, otherwise an error code.
