::mdlOption
This command will be used to create an option widget (combobox).
::model::mdlOption frmPath entityHandle dm
MotionView Tcl
path
The frame on which the option widget will be created is passed as an argument.
entityHandle
We need to pass the handle of the entity which contains the option data member.
dm
We need to pass the name of the data member that contains the list of option values.
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
::model::GetHandleFromFullVarname dsms MODEL.DS_MotionSolve_Simopts
set optSimType [::model::mdlOption $colFrm.optSimType dsms "analysis_type"]
pack $optSimType
dsms ReleaseHandle
On successful execution of the command, it will create an option widget.
