::RegisterTypedAnalysis
This command registers a new customized analysis entity type in MotionView.
::model::RegisterTypedAnalysis argPanel argFolder argPanelFile argPanelFunc argIconFile argShowBrowserFolder argForPair argDefinitionFile argDefinitionVarname argShowAsContainer argType
MotionView Tcl
argPanel
The variable name that is to be checked for validity.
argFolder
The text displayed in the folder in the browser that is to contain the instances of these entities.
argPanelFile
The full path of the file that contains the panel configuration. This file will be sourced to display the panel.
argPanelFunc
The name of the function in the “argPanelFile” that is to be called to initiate the display of the panel.
argIconFile
The file name of the icon that is associated with this entity type.
This registered entity type being displayed in a folder in the browser is determined by the value of this argument. If the value is true, the entity instances are displayed in a folder in the browser, otherwise they are not.
argForPair
If this registered entity type is for a pair, then this argument is true, otherwise it is false.
argDefinitionFile
The full path of the MDL definition fie that contains the definition to be used for this customized analysis entity type.
The definition varname (in the “argDefinitionFile”) that is to be used to define the customized analysis entity.
argShowAsContainer
If the contents of this customized analysis entity type are to be displayed in the browser, this argument needs to be true, otherwise it is set to false.
argType
The type that is to be assigned to instances of this customized analysis entity.
::model::RegisterTypedAnalysis analysis "Analysis" "NewAnalysis.tcl" "mainfunction" "Newanalysisentity.png" true false  Newanaldef.mdl ana_def_new true "NEWANALYSIS"
Error
On successful execution of the command, a new analysis entity will be registered.
