plt3DISurface GetHighlighted
Gets whether surface is highlighted.
plt3DISurface_handle GetHighlighted
HyperWorks Tcl Query
The appearance of a highlighted surface will change to indicate that it is active or has been picked through the GUI. To see this effect, alter the highlighted flag to cause a redraw of the client.
Returns true or false.
To check if an existing surface is highlighted:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName
mySurfaceName GetHighlighted
None.
