plt3DISurface SetMeshColor
Sets the color of mesh lines superimposed on the surface.
plt3DISurface_handle SetMeshColor color
HyperWorks Tcl Modify
The above example refers to colors by name, by RGB value, and by index.
color
A color identifier.
To set the mesh color of an existing surface to red, then white, then blue:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName 1
mySurfaceName SetMeshColor red
mySurfaceName SetMeshColor "255 255 255"
mySurfaceName SetMeshColor 4
None.
