plt3DISurface SetVisibility
Sets whether the surface is visible.
plt3DISurface_handle SetVisibility enabled
HyperWorks Tcl Modify
Surfaces can be rendered invisible without destroying them. If the visibility flag is set to false, a surface will simply not be drawn (and won’t appear in the legend). However, the surface will still be displayed in the surface list and can be made visible again by changing the flag back to true.
enabled
True
Highlighted
False
Not highlighted
To turn off the visibility of an existing surface:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetSurfaceHandle mySurfaceName
mySurfaceName SetVisibility true
myClientName Draw
None.
