plt3DIWaterfall GetNumberOfSlices
Gets the current number of slices in the waterfall.
plt3DIWaterfall_handle GetNumberOfSlices
HyperWorks Tcl Query
A waterfall can contain any number of curves. Unlike in the case of a curve group, the slices are assumed to be related curves and to share an orientation or direction.Returns the number of curves (an integer).
To get the number of slices in an existing waterfall:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName 1
myWaterfallName GetNumberOfSlices
Returns an empty string if the value is not defined.
