plt3DIWaterfall SetGenerateCurves
Sets whether the waterfall is visible.
plt3DIWaterfall_handle SetGenerateCurves enabled
HyperWorks Tcl Query
Waterfalls can be created in two ways: either by adding individual curves (slices), one at a time, or by defining matrices mathematically that are used to generate the constituent curves automatically.
enabled
Highlighted, true or false.
To make a waterfall math based:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName
myWaterfallName SetGenerateCurves true
myClientName Draw
Success (0) or an error code.
