plt3DIWaterfall RemoveSlice
Removes a slice from a waterfall.
plt3DIWaterfall_handle RemoveSlice index
HyperWorks Tcl Query
index
The index of the slice to remove (one-based).
To remove an slice from an existing waterfall:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetWaterfallHandle myWaterfallName
myWaterfallName RemoveSlice 1
None.
