pltIAnimationCursor SetUseCurveStyle
Determines if the style of the animation cursor bar (if it has a bar) is the same as the curve.
pltIAnimationCursor_handle SetUseCurveStyle state
HyperWorks Tcl Modify
This command determines if the style of the animation cursor bar (if it has a bar) is the same as the curve it is on. This command differs from the SetStyle command in that it sets whether the style of the cursor bar is the same as the curve, rather than setting the style of the cursor.
state
The input for the state variable is a true or false value.
true
If you want the animation cursor to be the same style as the curve it is on.
false
If you do not want the animation cursor to be the same style as the curve it is on.
If the curve is a solid line, the animation cursor bar will be a solid line either way.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetAnimationCursorHandle ach;
ach SetUseCurveStyle true;
Keywords
HyperWorks
Tcl
Animation Cursor
Modify
