pltIAxis GetRealValue
Gets the real value when the display value is input.
pltIAxis_handle GetRealValue display_value
HyperWorks Tcl Query
This command gets the real value when the display value is input. This command only works properly when the axis is scaled in dB20 or dB10.
display_value
A display value that you want to get the corresponding real value of.
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetClientHandle plot;
plot GetVerticalAxisHandle yaxis 1;
yaxis GetRealValue 30;
Success (the real value) or an error message is returned.
Keywords
HyperWorks
Tcl
Axis
Query
