pltIDatum SetAssociatedAxis
Sets the associated axis for the datum.
pltIDatum_handle SetAssociatedAxis axis_id
HyperWorks Tcl Modify
axis_id
The index of the axis to be used (must be positive).
If the datum is horizontal, this will be a horizontal axis. If the datum is vertical, this will be a vertical axis.
Returns success or an error code.
