pltIDrawControl DrawEllipse
Draws an ellipse.
pltIDrawControl_handle DrawEllipse ulx, uly, lrx, lry, style, width, color
HyperWorks Tcl Modify
Returns 0 = HW_Success or 3 = HW_InvalidHandle.
ulx
X-coordinate of the upper left point of a rectangle into which the ellipse is inscribed.
uly
Y-coordinate of the upper left point of a rectangle into which the ellipse is inscribed.
lrx
X-coordinate of the lower right point of a rectangle into which the ellipse is inscribed.
lry
Y-coordinate of the lower right point of a rectangle into which the ellipse is inscribed.
style
The index of the style to be used (must be non-negative).
width
The width to be used (must be non-negative).
color
The index of the color to be used (must be non-negative).
To draw an ellipse from (-.5, 1) to (.5, -1) with a style index of 1, a width of 3, and a color index of 2:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName
myPageName GetWindowHandle myWindowName
myWindowName GetClientHandle myPlotName
myPlotName GetDrawControlHandle myDrawer
myDrawer DrawEllipse -.5 1 .5 -1 1 3 2
None.
