pulIMacroParameter SetVariableName
Sets the macro parameter’s variable name, which is the name by which the parameter is referenced in expressions.
pulIMacroParameter SetVariableName varname
HyperWorks Tcl Modify
This command sets the variable name of the macro parameter to varname.
varname
The variable name used to reference the parameter in expressions.
hwi GetSessionHandle sess
sess GetClientManagerHandle pm plot
pm GetMacroHandle macro 1
macro GetParameterHandle param 1
param SetVariableName m1_param1
Returns 3 if there is an invalid parameter handle.
Returns 4 if varname is empty.
Keywords
  • HyperWorks
  • XY Plot
  • Tcl
  • Modify
