tblIRule SetCellList
Sets the list of cell names on which this rule should act.
tblIRule_handle SetCellList cellList
HyperWorks Tcl Query
To set up conditional formatting of table cells, you must first add a rule. Then, you must get the rule handle and set the relevant parameters on the rule handle. These parameters are used to decide the formatting of the cells that are part of the rule.
One such parameter is the list of cell names on which this rule should act. This API helps in setting the same.
cellList
The list of cell names. For example, A1 A2.
set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set ruleid [ch$t AddRule]
set ruleHandle [$activetableHandle GetRuleHandle rh$ruleid $ruleid]
$ruleHandle SetCellList "A1 A2 B1 B2"
puts "Rule Id: $ruleid acts on cells [$ruleHandle GetCellList]"
$ruleHandle SetBackgroundColor 3
$ruleHandle SetTextColor 0
$ruleHandle SetValue 10
$ruleHandle SetOperator ">"
$ruleHandle ReleaseHandle
Returns success(0) or an error code.
