2022
Compare video frames or overlay frames with other videos or images to watch them in flips.
View new features for HyperWorks 2022.
Explore the GeoD user interface.
The user interface provides you with a consistent look and feel when you are working in any of the HyperWorks applications.
Trace key points and objects in your video and set up a tracking system on an object in the video.
Apply annotations, headers, and footers to your video.
Creates a 4x4 horizontal or vertical page layout that displays a series of frames for up to four media files at specified time offsets.
Use the Overlay panel to alternate the display of overlaid images or movie files.
View All Altair Simulation Help
ON THIS PAGE
