2022
Apply annotations, headers, and footers to your video.
View new features for HyperWorks 2022.
Explore the GeoD user interface.
The user interface provides you with a consistent look and feel when you are working in any of the HyperWorks applications.
Trace key points and objects in your video and set up a tracking system on an object in the video.
Use the Headers panel to add headers and footers to your video images, specify font colors, and access the Font dialog.
Use the Notes tool to create on-screen label items and describe additional information such as media time and marker coordinates.
Compare video frames or overlay frames with other videos or images to watch them in flips.
View All Altair Simulation Help
ON THIS PAGE
