FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
From the HyperGraph menu, select Vector
Chart to display the Vector Plot ribbon.
Figure 1. Vector Chart Ribbon
Define
Edit existing curves and add new curves to the current plot.
Datums
Add horizontal and vertical datum lines to plots.
Tip to Tail
Displayed immediately upon curve selection, the tip-to-tail function calculates and draws the tip-to-tail function based on the current plot.
