FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
From the HyperGraph menu, select 3D
Chart to display the 3D Chart ribbon. Manage, review, and analyze
waterfall, surface, and 3D line data plots. Figure 1. 3D Chart Ribbon
