Data Query
The Data Query panel uses vertical cutting surfaces for viewing and plotting non-planer cross sections.
Surfaces can be defined by math expressions, specifying orders, and selecting points on the waterfall plot or 3-D surface plot.
Cut List
- All
 - Selects every query in the list
 - None
 - Deselects all highlighted queries in the list.
 - Flip
 - Exchanges the currently selected queries for the unselected queries in the list.
 - Delete
 - Deletes a section query.
 - Add
 - Adds a new section query.
 - Add n...
 - Adds a specific number of queries.
- Order
 - Passes a query surface through an order.
- Input vector
 - XY vector which contains the driving or input vector for the waterfall plot.
 - Time vector
 - XY vector which defines the time values used to create the waterfall plot.
 - Order
 - Select the order that you want to query. You can enter the values manually or left-click on an order in the waterfall plot.
 - Input vector is in RPM
 - Select this option to scale the response curve by 60 to use RPS.
 - Apply
 - Click Apply to create/update the query surface.
 - Equation
 - A math equation defining a curve on an XY plane.
- X
 - Math expression on the XY plane, along the X axis.
 - Y
 - Math expression on the XY plane along the Y axis.
 - Point List
 - Create a curve on the XY plane by picking the X, Y, and Z points.
- X, Y, Z
 - Click in the X, Y, and Z fields to enter values.
 - Add Row
 - Click Add Row to add a row to the table.
 - Delete Row
 - Select a row and click Delete Row to delete the row from the table.
 - Clear Table
 - Clear the contents of the table.
 - Move Arrows
 - Use the up and down arrows to move between rows.
Layout
- Layout
 - The Layout option allows you to specify how the plotted data is arranged
                            on a page.
- One plot
 - Data is arranged on one plot.
 - One plot per cut
 - One plot is created for each vertical cutting surface. The Page Layout button is activated when you select this option. Choose a page layout type from the pop-up dialog.
 - New plot
 - Curves are plotted in a new plot window.
 - Create curve
 - Creates an XY curve of the 3D plot cross section.
