Export Hotspot Finder Criteria
- Open the Hotspot Finder dialog by clicking on the guide bar.
- From the top right corner, click the Export icon and select the desired location to store the hotspot configuration file.
View new features for HyperWorks 2022.
Explore the GeoD user interface.
Query and view key information about selected entities live when in idle mode.
Use the Query tool to view and export properties and other information for nodes, elements, components, and systems contained in the active model.
The Free Body Diagram (FBD) tool facilitates the extraction and post-processing of Grid Point Force (GPFORCE) results and can be used create and edit Free Body Diagrams (FBD).
Use the Plots tool to construct multiple curves and plots from a single result file.
Starting in version 2021, the Stress Linearization tool has been renamed as Extract-Linearize and will support both the Extract Data and Stress Linearization methods.
Use the Hotspot Finder tool to find critical regions of your model based on a plotted result, filter the entities based on selection set, threshold values, minimum separation, and load cases. In addition, you can plot the search results with annotations and selective amount of details displayed on screen.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
