Change the Entity Type
From the panel, click the entity type
selection switch
to access the pop-up menu of possible entity types.
- Select the type that you want to use.
View new features for HyperWorks 2022.
Explore the GeoD user interface.
Animation files are opened using the Load Model panel.
Use the Measure tool to measure various distances and angles between entities.
The Results Browser allows you to view the HyperView model structure while providing find, display, and editing control of entities.
Use the Parameters Browser to parameterize the contents of a session file or report template and automate a variety of analysis processes in Altair HyperWorks Desktop.
Entities can be selected using input collectors or the quick window selection method.
Input collectors allow you to select entities in a model to which you can apply various tool functions.
The extended entity selection menu provides a number of entity selection options.
Locator strings can be used to identify node/element/parts within a model.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
