Load Results Only
- From the Load Model panel, activate the Load results check box.
 - If necessary, deactivate the Load model check box.
                Click the file browser button,
, next to Load
                        results and select a results file.
                Click Apply.
                The results file is loaded and applied to the current model specified. A results table is created for post-processing.Note: To change the specified current model, right-click on the name of the model file in the Results browser that you would like to set as the current model, and select Make Current from the context menu.
