Use the Tensor tool to show stress and strain directions and magnitudes for various
solvers from elemental values.
Restriction: Only component display mode is
currently supported.
From the Post ribbon, click the Tensor tool.
Select a tensor plot using the drop-down menu on the guide bar.
- Optional:
Click the Create Tensor satellite icon to define a new
tensor plot.
- Optional:
To review and edit the current plot definition, click
on
the guide bar.
- Optional:
Select a subset of components or elements on which to apply the plot.
By default, the plot is applied to the entire model.
Click Plot to display the plot.
Click one of the following:
- Save changes and exit the tool
- Clear the plot
Exit the tool without saving changes
Tip:
- Plots are based on the current load case and step, which can be reviewed and
updated from the status bar or the browser.
- Existing plots can also be displayed or cleared using the plot icons in the
Results Browser.
- Editing the definition for a displayed plot will automatically update the
graphics. For large models, editing the plot definition may be faster if the
plot is not displayed.
