FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Use the Spline tool to define the coupling/interface between the structure model (through the SET1 entity) and the
aero model (through the AELIST entity), respectively called structure and aero surfaces.
