Import and Plot Flutter Curves
Use the Flutter Curve tool to process flutter data by cross-plotting selected result quantities from the flutter solution results.
View new features for HyperWorks 2022.
Use the Panel Mesh tool to select up to four locations to define the domain for the CAERO1 panel.
Use the Body Mesh tool to define the body type of aerospace meshing called CAERO2.
Use the Engine Mesh tool to define the engine or missile modeling and meshing.
Use the Spline tool to define the coupling/interface between the structure model (through the SET1 entity) and the aero model (through the AELIST entity), respectively called structure and aero surfaces.
Use the Control Surface tool to define controlling surfaces and required data.
Use the Monitor Points tool to define the types of monitor definitions.
Use the Aeroelasticity Browser to build a model for three of the aeroelasticity solution sequences for Nastran (MSC) users.
Explore the GeoD user interface.
