Use the Control IDs from Selection tool to create a list of selected nodes/elements,
        review and control IDs.
        Once nodes or elements are
            selected, you can collect entity IDs and obtain a list.
                From the menu bar, click .
                Select nodes or elements.
You can copy, paste or delete the list and write specific IDs.
                Use the context menu to make your selections.
                Filter the element selection by selecting enable filter, configuration or
                    type.
                    Note: The filter must be set before you select the elements.
