Define Connector Controls
Use the Control Manager to create and edit the various types of controls that will be used later when realizing connectors.
From the Connectors ribbon, click the Controls
tool.
Figure 1. - Optional:
At the top of the dialog, click
to open an .hm binary file that contains saved connector
controls, or click
load in an FE_Config file.
- Use the tabs below to cycle between controls for each group (Point, Fastener, Line, Area, Attachments, Connect Attachments, and Elines).
Right-click and select Create then edit the
following.
- Name
- Describes the realization in terms of its real-life representation, such as a resistant spot weld or a self-piercing rivet.
- Type
- The Finite Element realization that is representing the engineering entity.
- Engineering Name
- A mechanism to organise by a defined set or categories outlined by the xMCF (χMCF) format.
Tip: Right-click on a control to duplicate or delete it. -
Select a control then use the right side of the dialog to manage how the
control will be realized.
Multiple controls can be selected and edited simultaneously. The parameter list will be filtered, leaving only the common fields available to edit.
- Optional:
to save the defined controls to your active folder,
or click
to save the controls to a folder of your
choice.
- Click OK.
