Assemblies
Assemblies collect and organize sub-assemblies and components into hierarchical data structures which are intended to reflect the data structure of the product being modeled.
Operations performed on an assembly do not affect the sub-assemblies or components collected within the assembly. For example, if you delete an assembly, the sub-assemblies or components in the assembly are not deleted.
PAM-CRASH Cards
| Card | Description |
| MBSYS/ | Describes an assembly of multibodies |
Radioss Cards
| /SUBSET | Describes subsets. Note: Block Format Keyword
