Vector Collectors and Vectors
Vector Collectors
Vector collectors collect and organize vectors.
Nastran Cards
| Card | Description |
| SNORM | Defines a surface normal vector at a grid point for CQUAD4, CQUADR, CTRIA3,
and CTRIAR shell elements. Note: There is no card image
associated with the collector. In order to view the actual SNORM cards, each
vector must be individually card edited. Loading the SNORM card image onto the
collector assigns the SNORM type onto all of the vectors contained in that
collector.
PAM-CRASH Cards
| ADAPT / | |
| PICK / | |
| SUBDF / | Substructure definition |
Vectors
Vector entities allow for the definition of a vector in 3D space. Vectors can be created using three methods; base & magnitude, two nodes, or cross-product.
LS-DYNA Cards
| *DEFINE_SD_ORIENTATION | Define orientation vectors for discrete springs and dampers. |
| *DEFINE_VECTOR | Define a vector by defining the coordinates of two points. |
